I got a few questions about timing belt/waterpump install
I started my timing belt,water pump and tensioner last night. Everything was going well untill i broke a bolt that holds the water pump on flush with the block... How should i fix this? its hard to get up there because the frame is right in the way. Are those 6 bolts different sizes?
Also do you put lock tight on any of the bolts or the tensioner bolts?
Modified by zach1288 at 2:30 PM 6/28/2007
Re: I got a few questions about timing belt/waterpump install (zach1288)
If you torque them down right you should not need Loctite, Honda doesn't use it. The water pump bolts are all the same size.
Try to get a pliers in there and turn it out, your kinda on your own there...
