Swapping a b series in my ek...few questions i needs answered
Hey guys i will be dropping my b20vtec this weekend and i just wanted to know if i can use my stock throttle cable on my sk2 manifold...and can i use my stock radiator hoses and vacuum hoses that go on behind the block??? i also have some rc injectors sl2's, but i dont know what injector clips to use..any input will be great thx guys!!
Modified by b20beast978 at 6:38 PM 6/28/2007
1. Yes the water hoses behind the block that attach to heater and stuff will all work fine.
2. You might be fine with your stock throttle cable but it depends on what stay (the attachment bracket on the manifold) you use. If you have a Teg one probably won't work, use a 99-00 Si bracket.
3. Generally the RC injectors require the use of OBD1 injector clips or ones you can get from RC that fit also.
thx man...i was curious about the hoses, but i got the throttle stay bracket from 99-00 si and i tried using obd 1 clips but they didnt work so i guess i will call up rc and see what they say!!
Correct me if I misunderstood but were you saying both the throttle cable bracket AND injector clips didn't fit, or just the injectors...
Also are you using a GSR head or B16?
I'm getting ready to drop a JDM B16 myself into my EK, it's replacing a stock B18B. I picked up the 00 Si throttle cable and bracket, as the Y7 cable does work but it's extra long and kind of unsightly.
thx for your inputs dude i really appreciate it...i am going to be dropping the motor this weekend and i didnt want to be held up cause of little things like that. I just wanted to be reassured so it can be as smooth as possible
Hope it all goes well for you. I was hoping to install mine this weekend too but the guy I bought my tranny from hasn't shipped it yet so looks like it'll have to get put off. If you run into anything while installing it let me know.
One more thing, have you swapped out the stock D-series radiator for the Si one? Because the radiator inlets on the D-version are smaller than the water pipes on the B-series motor and you might have a tough time getting a single-diameter hose to fit. The Si is the same core but has endtanks with larger necks to match the motor.
Re: (klungemonger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger »</TD></TR><TR><TD CLASS="quote">Hope it all goes well for you. I was hoping to install mine this weekend too but the guy I bought my tranny from hasn't shipped it yet so looks like it'll have to get put off. If you run into anything while installing it let me know.
One more thing, have you swapped out the stock D-series radiator for the Si one? Because the radiator inlets on the D-version are smaller than the water pipes on the B-series motor and you might have a tough time getting a single-diameter hose to fit. The Si is the same core but has endtanks with larger necks to match the motor.</TD></TR></TABLE>
yea somebody told me to go with the del sol b16 radiator since it had the bigger inlets and was dual core..so i was going to wing it for now and use the stock d series until i can get my hands on a higher end radiator su ch as koyo or fluidyne
Re: (b20beast978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20beast978 »</TD></TR><TR><TD CLASS="quote">yea somebody told me to go with the del sol b16 radiator since it had the bigger inlets and was dual core..so i was going to wing it for now and use the stock d series until i can get my hands on a higher end radiator su ch as koyo or fluidyne</TD></TR></TABLE>
Hope it works for you, you'll have to get an adjustable clamp and crank on it pretty hard to make it seal up and not leak fluid all over...I picked up a used 00 Si stock radiator for $50, it's only single core but has worked fine for me. Maybe hunt one of those down, try Ebay or something...
I too have just done a b swap to my ek. I've made multiple threads on what I need. As for the radiator, you need the del sol vtec because it has bigger outlets and inlets. I just bought an oem si and it didn't work for me. It leaks. So I will buy an ebay alluminum that works for b series.
so any del sol vtec radiator should do the job then i guess...i could have sworn the 99-00 b16 single core would have worked since the outlets were bigger but i guess not..
Re: (b20beast978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20beast978 »</TD></TR><TR><TD CLASS="quote">so any del sol vtec radiator should do the job then i guess...i could have sworn the 99-00 b16 single core would have worked since the outlets were bigger but i guess not..</TD></TR></TABLE>
No you are correct, the 99-00 Si does work, I am using it right now! That guy probably got one from the D-series Si not the B16 model. Either that or he got ripped off and was sent the wrong one. The 99-00 Si one DOES work. The main difference is that it is single core.
Re: (klungemonger)
ohh thats wassup!!! im pretty sure i can find someone selling a 99-00 si one around here since they are common, but the del sol vtec is pretty rare. not too many del sol b16's around here man
you should research "ebay b series radiators." Lots of people has had success with these. I'll be picking one up for at 80 bux and it'll work with my application as the nipples are 1.25 inches in diameter needed for b series swaps. Plus it's all aluminum which gives it that JDM blingage.
Azxster
03-27-2008 06:57 AM
SiR831
11-16-2002 08:09 PM
