i cant figure out how to stop the leaking????
i have leaking from my distributor and i change the o ring and it is still leaking..any ideas to try would help. thanks i have a b16a with skunk2 cams if that would change anything.
Unceasing Measure
Re: i cant figure out how to stop the leaking???? (brianironmanbaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brianironmanbaker »</TD></TR><TR><TD CLASS="quote">how would i go buy fixing that
If it is indeed the camshaft seal, you simply replace it. If you're sure the distributor is the culprit, make sure the metal behind the dizzy and above the cam journals isn't damaged.
the_dxB16
10
03-05-2008 10:54 AM
efking
09-28-2006 12:44 PM
