manual transmission
manual transmission
hi im new here and have just a couple Q's about the manual that i need answers 2:
1st when i have to stop do u press and hold the clutch and shift into neutral?
also do i keep holding the the clutch down at the stop sign or i let go of it?
2nd do i always have to start in first gear?
thx in advance
thx in advance
Re: manual transmission (tehdj08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tehdj08 »</TD></TR><TR><TD CLASS="quote">hi im new here and have just a couple Q's about the manual that i need answers 2:
thx in advance
#1: I usually downshift when coming to a stop instead of rolling in neutral (unless I'm already going slow). You can put the car in neutral at a stop and foot off the clutch pedal if you are waiting at a light. Sometimes I leave the car in 1st gear with the clutch down.
#2: You don't have to start in first gear, but you can burn your clutch by riding it trying to pull out of 2nd gear. Stick with 1st.
thx in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tehdj08 »</TD></TR><TR><TD CLASS="quote">so will leaving it in first gear + clutch pushed at a stop light hurt the tranny in any way?</TD></TR></TABLE>
Nope
Nope
Re: manual transmission (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">u can start with 2nd gear when u are on a icy road</TD></TR></TABLE>
You can start in 5th if you are on jackstands lolol.
Start in first gear with a civic, starting in 2nd will wear your clutch out real fast.
Re: manual transmission (97Ej6mike)
You should double clutch to downshift. This will lengthen the life of your tranny.
As long as you are in Neutral, it does not matter what you do with the clutch. Just going in and out of gears
bg2128506
Acura TL, RL & ZDX
07-15-2013 11:23 AM
ChillEDogg
02-22-2011 04:47 PM
kotetu
05-29-2003 05:51 AM
CPR
12-17-2001 08:57 PM
