speed sensor/thermostat problem
New User
has anyone had problems w/ their speed sensor n reverse light??? i've changed out speed sensor...thought it was the wire harness changed that too, still not workin...also thermostat won't open w/ motor runnin but tested w/ boiling water it opens...any suggestions???
HRD PKR
Re: speed sensor/thermostat problem (n4rk0)
so you replaced your vss? correct?
and your reverse lights dont work'?
your really confusing. how is the thermostat ground?.
What model do you have? My '92-'95 model year has a reverse "sensor" I had to replace; it's on top of the tranny...I needed a Cresent wrench to get it off.
