OBD1 B16 and GSR harness the same?
I have a JDM OBD1 B16 swap that needs a harness. I have someone telling me a ODB1 GSR harness will work, all plug and play. It this correct? Are the harness's the same?
Thanks
Thanks
O.G. triple O.G.
Re: OBD1 B16 and GSR harness the same? (kpowerdhatch)
Yes, the harness will work. You will have some plugs that will not be used. (knock sensor, secondary butterlies)
O.G. triple O.G.
Re: (islandauto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by islandauto »</TD></TR><TR><TD CLASS="quote">The harness will work but u might get a check engine light for sensors not plugged in</TD></TR></TABLE>Wrong...if he is just using the harness not a GSR ecu, it WILL NOT throw a code because there is no sensor to detect.
Re: (islandauto)
dont listen to this guy. it will work fine you will have some extra plugs and it wont throw a code because your ecu wont be looking for it
Re: OBD1 B16 and GSR harness the same? (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo »</TD></TR><TR><TD CLASS="quote">Yes, the harness will work. You will have some plugs that will not be used. (knock sensor, secondary butterlies)</TD></TR></TABLE>
yea p30 has a knock sensor,.
what would i need to do to use an obd0 harness with an obd1 ecu? would the conversion harness plug in or do i need to solder some wires?
O.G. triple O.G.
Re: OBD1 B16 and GSR harness the same? (aleks708)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aleks708 »</TD></TR><TR><TD CLASS="quote">what would i need to do to use an obd0 harness with an obd1 ecu? would the conversion harness plug in or do i need to solder some wires?
</TD></TR></TABLE>You can purchase a conversion harness for around $75 or so. For that much money, you can actually find one WAY cheaper from Pull-A-Part Salvage, even if it is a Non-VTEC harness.
jdmekrobot
03-13-2008 12:13 AM
Usdmowns
11-30-2007 04:01 PM
