Clutch problem? need help
Hey guys, my 93 si is having a problem. One of my buddies drove it and now i cant change gears. i can step on the clutch and turn on the car but i cant put it to first or any other gears. the car is bone stock not sure what clutch cause i just got it and they told me they just put in a new one. Any info would help thanks !
Re: Clutch problem? need help (Si93_22)
try starting your car in gear. If it lurches then your clutch isn't disengaging. I've had 2 clutch go out on two different preludes. I believe a spring popped outta the disc
could have an air bubble in the slave cylinder line or outta/low on fluid.
Does your pedal pop back normal or does it stick to the floor
If the pedel sticks to the floor then you better check your clutch fluid.
You might have a leak in the line or very little fluid left.
Also check with your friend if he do anything to the car.
