will 14 inch rims fit on GSR DISK CONVERSIOn?????????
hey im just wondering whats the smallest rim that can fit a 94-01 GSR disk brake conversion. i know 15 inch rims work but and that 13 inch rims wont work so my question is.... do 14 inch rims fit???/ need answer ASAP since im going to need to buy donuts tomorrow. THANKS!!
Re: will 14 inch rims fit on GSR DISK CONVERSIOn????????? (EKbeast)
Im not 100% sure but arn't del sol vtec brakes the same as a gsr's?
If so 14's should be fine cos thats what del sol vtecs come with from the factory
Re: will 14 inch rims fit on GSR DISK CONVERSIOn????????? (Aushonda)
hmmm.. not sure about that. but if del sol and gsr disk are same, than u answered my question. BUMP
HT White Ops
It depends on the offset and wheel width.
Take the 92-00 EX/Si brakes (10.3"). These are the same size as the Integra brakes. The 14x5.5 +45 HX (made for a 9.5" rotor) standard wheels do not fit over these without a 5mm spacer (-5 ET). The stock 14x5 +45 steelies with hubcaps, and also many of the HOP Optional wheels for 5th and 6th generation Civics do not need a spacer, because they are half an inch narrower.
Re: (Eran)
so will 14 inch donuts (not sure from which model) fit on my 94-01 GSR integra disk brakes? ive tried HX wheels once before but didnt fit yet they were 13 inches. im just going to stick with 14 donuts/steelies but will they fit?
HT White Ops
Re: (EKbeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKbeast »</TD></TR><TR><TD CLASS="quote">so will 14 inch donuts (not sure from which model) fit on my 94-01 GSR integra disk brakes? ive tried HX wheels once before but didnt fit yet they were 13 inches. im just going to stick with 14 donuts/steelies but will they fit? </TD></TR></TABLE>
If you get the 14x5 stock steelies from a 92-00 EX/Si, then yes, they will fit over 10.3" brakes.
By the way, if your "HX's" were 13-inch, they were VX wheels.
HX (14x5.5):
VX (13x5):
HX (14x5.5):
VX (13x5):
HT White Ops
Re: (EKbeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKbeast »</TD></TR><TR><TD CLASS="quote">o yeah, they were 14's. so 14 inch donuts from 92-00 civic or 94-01 integra (mostly likely LS) will fit on the GSR disk brakes?</TD></TR></TABLE>
You got it.
You got it.
EKbeast
12-10-2007 01:02 PM
EKbeast
11-05-2007 09:22 AM
