Burning Oil
Burning Oil
Hi I posted awhile back about my car burning oil randomly well I have been keeping track of the oil levels for about 2 weeks now (checked every day) this is what I came up with. I changed my oil and 2 weeks after (700-750k) my cars oil level droped from upper mark to middle. The only thing I never did that day was let my car warm up before I drove off after work thats all anyone know whats wrong ? if it was rings and or valve seals wouldn't it burn oil always ? I have a b16a3 motor with 130k on it is this a problem with b16 motors ? Also I never went past 4000 rpm (No vtec)
Edit- I also replaced the drain plug washer when I did the oil change.
Edit- I need a valve adjustment done would this cause oil to burn ?
Darth ModerVader
Re: Burning Oil (jit01)
If you're consuming less than 1 quart per 1600 KM (which seems to be close to what you're describing), I wouldn't be terribly concerned.
Re: Burning Oil (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">If you're consuming less than 1 quart per 1600 KM (which seems to be close to what you're describing), I wouldn't be terribly concerned. </TD></TR></TABLE>
well its only been like 750k since oil change. I need a valve adjustment done would this cause oil to burn ? I am using valvoline oil (regular) 5w 30
Re: Burning Oil (Midori Green)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green »</TD></TR><TR><TD CLASS="quote">no oil passes thru the valves so it wouldnt make a difference</TD></TR></TABLE>
Man anyone have any idea's ? This has been bothering me for awhile now. I know its not that big of a deal but I feel like the car is crapping out which I dont want to happen..
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jit01 »</TD></TR><TR><TD CLASS="quote">well its only been like 750k since oil change.</TD></TR></TABLE>
Yes, but you've only consumed around 1/2 quart, from what you're describing. Do a compression test, and at the next oil change, try switching to a high-mileage formula. Again though, I don't think you have cause for concern.
on my motor i use castrol high mileage and even tho my motor burns no oil i still use it and always use an oil additive with everyoil change... and please stay away from the 5w-30 oil viscosity too light your motor will burn oil slower if u use 10w- 30
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green »</TD></TR><TR><TD CLASS="quote">on my motor i use castrol high mileage and even tho my motor burns no oil i still use it and always use an oil additive with everyoil change... and please stay away from the 5w-30 oil viscosity too light your motor will burn oil slower if u use 10w- 30</TD></TR></TABLE>
Yeah, use 10w-30 or 10w-40 if you feel like letting your car warm-up a bit extra at the gain of lower burning of oil.
Stay away from full synthetics as they leak/burn more. Like midori said, castrol high mileage is a good answer if its weighted a bit.
Re: Burning Oil (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
Stay away from full synthetics as they leak/burn more. Like midori said, castrol high mileage is a good answer if its weighted a bit.</TD></TR></TABLE>
ok does this mean my valve seals need to be replaced ? I am trying to find out whats causing it I hope its not the rings.. If its the valve seals I am going to get them replaced
