My gauge needles don't light up !?
Old 10-30-2007, 03:21 AM
joe.wong321's Avatar
Default My gauge needles don't light up !?
None of my needles light up
I can't read a **** at all at every night I drive
Are there anyway to fix it ?
I read from this theard below said
https://honda-tech.com/zerothread?id=1473130
SI needles do NOT light up. A light behind them kinda makes them look illuminated.
Thanks
Modified by joe.wong321 at 3:00 PM 10/30/2007
Old 10-30-2007, 05:08 AM
nix94delsol's Avatar
Default Re: My gauge needles don't light up !? (joe.wong321)
new bulbs?
Old 10-30-2007, 05:16 AM
rleonekc's Avatar
Default Re: My gauge needles don't light up !? (nix94delsol)
fuse?
Old 10-30-2007, 05:41 AM
Default Re: My gauge needles don't light up !? (rleonekc)
Common Sense?
Old 10-30-2007, 06:07 AM
ej8_vtec's Avatar
...I'm pretty sure theres two lights at the top of the cluster that shine down onto the gauges.
Old 10-30-2007, 06:11 AM
97Ej6mike's Avatar
Default Re: (ej8_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8_vtec &raquo;</TD></TR><TR><TD CLASS="quote">...I'm pretty sure theres two lights at the top of the cluster that shine down onto the gauges.</TD></TR></TABLE>
X2.
92-00 civics dont have separate lights just for the needles, like all newer cars have, lol.
Old 10-30-2007, 06:15 AM
Ryan.'s Avatar
Yeah there are two little bulbs on the top of the cluster that shine down. Check them and if that's not the problem change out the two main bulbs in the rear of the cluster.
Old 10-30-2007, 10:43 AM
Default Re: (Ryan.)
I did pulled the gauge out once and checks the main 5 bulbs (1 x #194 bulb & 4 x #74 bulbs)
they all lights up and this should be why the whole gauge face can light up
are they not bright enough to shine the needles or
are there any more bulbs that actually shine down that I should check
or which 2 exact bulbs I should check ?
BTW, none of my bulbs have the blue rubber thing
Thanks for the reply and help
Really appreciate if I can see the needles again at night
lol ........
Old 10-30-2007, 10:49 AM
SpeedoKing's Avatar
it could be the picture but it looks like you have the light dimmed all the way down jus turn it up and even if they needle lights are out it should be bright enough to read.
Old 10-30-2007, 10:56 AM
ej8_vtec's Avatar
Default Re: (joe.wong321)
Here I tried to use your picture as a reference point... But where I circled in yellow is about where they'd be, they're on top of the cluster, closest to you if you were looking at the front, two little bulbs that shine down onto the needles... Sry for the crappy description but its the best I could do while at work
Old 10-30-2007, 11:05 AM
Look what I just found.....
"Pull out the dimmer switch in the left air vent and inspect it. I had the same problem you had, I was using indigo gauges and everything was fine, pulled them out and none of the dash/climate lights worked anymorel. Pulled out the dimmer switch and it looked burned on the inside. Well i replaced it and everything worked fine again."
Will the dimmer switch be a problem too ?
Old 10-30-2007, 11:14 AM
ej8_vtec's Avatar
umm if the dimmer switch was busted but turned all the way down you'd still have light thru the gauges even from the top two. I would replace that switch anyways so you can at least make it brighter than before but still check those two top bulbs, if thats no it then i dunno i'm out of idea's
Old 11-05-2007, 11:20 AM
Thank you guys for all of ur help
I found those two bulbs and it works
but does anyone know where can I get that bulbs, I tried autozone and they said they never hv any small bulbs like that
even I bought #74 for the gauge, it's not actually fit perfecty
I need the grey socket kind of bulbs (the blinker's ones) and the grey socket
Thanks again ...
Old 11-05-2007, 11:31 AM
HT White Ops
Eran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joe.wong321 &raquo;</TD></TR><TR><TD CLASS="quote">Thank you guys for all of ur help
Thanks again ...</TD></TR></TABLE>
You can get #74 and #24 bulbs from Autozone or CSK. The illumination for the cluster requires 4 #24 bulbs and 1 #194 bulb. The downward illumination is 2 #74 bulbs. The climate control is also 2 #74 bulbs.
Old 11-05-2007, 11:51 AM
but those bulbs from autozone never fit like the stock ones in the cluster
where can I get the stock?
Old 11-05-2007, 11:53 AM
HT White Ops
Eran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joe.wong321 &raquo;</TD></TR><TR><TD CLASS="quote">but those bulbs from autozone never fit like the stock ones in the cluster
where can I get the stock?</TD></TR></TABLE>
Are you ******* kidding?
You get stock Honda parts at the Honda dealership.
By the way, if they don't fit, you're buying the wrong bulbs.
Old 11-05-2007, 12:01 PM
KSWEST's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
By the way, if they don't fit, you're buying the wrong bulbs.</TD></TR></TABLE>
uhm. yah. head out of the *** please. there are 2 honda dealerships w/in driving distance.... downtown honda and valley honda/ acura... Go forth and fix your gauge cluster....
DraginTeg93
01-16-2008 06:30 AM
emotionisdead
11
08-27-2006 02:29 AM
SIKSI
Honda S2000
07-24-2006 11:57 PM
sirpsychosexy1
07-08-2005 11:28 AM
tegsp
11-28-2004 05:40 PM
Quick Reply: My gauge needles don't light up !?
