antenna block off plate
Re: antenna block off plate (ej8freek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8freek »</TD></TR><TR><TD CLASS="quote"> When you install the block-off plate, how do you take apart the antenna? Doesn't that mean you'll get no reception for radio? </TD></TR></TABLE>
the point of the plate is if you are running a radio block off plate (i am) or you have satelite radio and dont use am/fm
Dont get the blockoff plate if you want to keep your antena
i have the atenna block off plate. my antenna is relocated towards the spoiler on the roof, kinda like on the vw jetta's. i bought it like that though.
the block off plate basically is a relocator. it closes off where your antenna is and then you really dont have one unless you install one somewhere else
theres a special tool to take off the thing its like a horseshoe shape with 2 little flat ends... it fits on and you can take it apart rather easy check your other post about antenna.. i wrote something in there for ya. also a new antenna kit comes with the tool to remove the old.
Re: (Bazza)
can someone give me the part # for the antenna plate block off and the gasket for 97-00 civics ... dealership is confused and can find only EG ones
Re: (robble36)
Bringing this one back....
I ordered the plate and rubber gasket and screws from majestic. Is there another back piece to the block off? I seem to be missing the location that the plate screws into. Help? Anyone?
memoryFAB.com representative
Re: antenna block off plate (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">i have the antenna block off plate and i took off the whole antenna assembly .</TD></TR></TABLE>
as did i..
as did i..
No block of plate is to make it cleaner.
i have the block off plate and then i purchased a metra antenna and have the antenna in my dash.
boom clean smooth car with radio still.
thx god i have the fing radio my hasport mounts makes cd playing impossible.
Re: (addsmack)
to my recolection, the blockoff plate is the plate itself, a rubber gasket, and 2 screws. i picked mine up at a junkyard. that should be all you need.
Re: (addsmack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by addsmack »</TD></TR><TR><TD CLASS="quote">
It screws straight into the roof, there is no back plate.
Re: (saywhat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saywhat »</TD></TR><TR><TD CLASS="quote">
It screws straight into the roof, there is no back plate.</TD></TR></TABLE>
also a good place to find these is on ebay. they go for pretty cheap and they are still OEM honda.
I just pushed my antenna down into the a pillar, i didn't feel like pulling it out. I did notice that one of the screws is a little long and doesn't put very much pressure on the gasket, im going to reverse the screws to see if that makes a dif.
Re: (electron_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electron_si »</TD></TR><TR><TD CLASS="quote">
I just pushed my antenna down into the a pillar</TD></TR></TABLE> That's what I did too.
Did you order #10, or a generic civic antenna block off plate?
Im guessing the latter, huh?
The civic block off plate is pretty different, and designed for A pillar mounted antennas (as you probably figured out). I wasnt even aware that S models were offered w/o a radio...
(plate # 39152-SR2-A00)
(screw # 93903-444G0)
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">take it to a autobody shop, get it filled and painted over, block off plates are gay.</TD></TR></TABLE>
good answer
good answer
