AEM WB o2 install question
Old 10-29-2007, 09:48 AM
slowteg90's Avatar
Default AEM WB o2 install question
The AEM wideband goes into the civic today, but I ran into a problem. I need to know which wire going into the ECU is the signal wire for the o2 sensor. The chassis is a 1992 cx hatch, with a 99 gsr swap, OBD1 harness was used.
TIA.
Modified by slowteg90 at 4:11 AM 10/30/2007
Old 10-29-2007, 11:28 AM
slowteg90's Avatar
Default Re: AEM WB o2 install question (slowteg90)
Old 10-30-2007, 03:11 AM
slowteg90's Avatar
Old 10-30-2007, 10:03 AM
slowteg90's Avatar
nobody wants to help me?!?!?!?!!??!v
Old 10-30-2007, 02:28 PM
P12 EG6's Avatar
the white wire is the 0-5v output wich you should use as the 02 wire... dont used the blue
Old 10-30-2007, 04:59 PM
slowteg90's Avatar
Default Re: AEM WB o2 install question (P12 EG6)
Yeh your right, I hooked it up about 3 hours ago.. unfortunetly I learned my car is running ***** rich... high 10's AFR
Markb16a
12-02-2006 05:40 PM
NitrousB.I.G.
08-15-2006 06:27 AM
SpeedMonkeyRacing
05-12-2003 12:41 PM
BoostedSi
03-23-2003 09:13 AM
Quick Reply: AEM WB o2 install question
