Rear Lower Tie Bar - Finally got it mounted!!! Check it out!
Old 10-29-2007, 05:56 PM
EG-Honda's Avatar
Default Rear Lower Tie Bar - Finally got it mounted!!! Check it out!
Designed and made myself! With the help of my fellow machinest.
Just need to mount th sway-bar!
Can't belive the change already with just the new brace.
Tell me what ya think1
Old 10-29-2007, 06:08 PM
ke98248's Avatar
Default Re: Rear Lower Tie Bar - Finally got it mounted!!! Check it out! (EG-Honda)
Not bad looking
Old 10-29-2007, 06:09 PM
stock_honda_coupe's Avatar
I might want to try that, I have access to a limited amount of machining tools. What did you use for a template? Its aluminum right? How thick? And I'm curious what sway bar you are useing too.
Old 10-29-2007, 06:23 PM
Harryflores's Avatar
Default Re: Rear Lower Tie Bar - Finally got it mounted!!! Check it out! (stock_honda_coupe)
Old 10-29-2007, 06:34 PM
trrbl1bmx's Avatar
nice peice!! how much? pm me
Old 10-29-2007, 06:56 PM
SpeedoKing's Avatar
Default Re: (p00n)
i know this is a bit of a stupid question but what is the difference between this and a sway bar dont they do about the same thing?
props man it looks great
Old 10-29-2007, 06:57 PM
JKov240's Avatar
Default Re: (SpeedoKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedoKing &raquo;</TD></TR><TR><TD CLASS="quote">
i know this is a bit of a stupid question but what is the difference between this and a sway bar dont they do about the same thing?</TD></TR></TABLE>
The brace acts as a reinforcement so you don't have tear out your subframe when you use a larger rear sway bar.
So, it stiffens up your rear end and prevents damaging your subframe.
Old 10-29-2007, 08:12 PM
instrument's Avatar
i'd buy one if it were black and didn't say pms uspension on it.
Old 10-29-2007, 09:06 PM
92ehatch's Avatar
Default Re: (instrument)
what type of aluminum did you use?
also, would you be willing to pm me some dimensions for that, ive been wanting to make my own as well.
thanks if you can do that,
Old 10-30-2007, 06:02 AM
EG-Honda's Avatar
Default Re: (92ehatch)
Aluminum is T-6061 - or Aircraft grade if that gets you excited. i won't say anything about a selling until i have mounted the sway-bar and can verify the whole thing works!
Old 11-01-2007, 05:46 AM
EG-Honda's Avatar
Now Availiable!!
https://honda-tech.com/zerothread?id=2139492
Modified by EG-Honda at 11:22 AM 11/1/2007
Old 11-01-2007, 06:01 AM
audiko4's Avatar
Looks good
Old 11-01-2007, 07:22 AM
Agent_EM1's Avatar
not bad
Old 11-01-2007, 07:26 AM
SeVeNisOnE's Avatar
Looks pretty good to me. You should polish it up to a mirror like finish.
Old 11-01-2007, 06:35 PM
EG-Honda's Avatar
Default Re: Rear Lower Tie Bar - Finally got it mounted!!! Check it out! (SeVeNisOnE)
Pics of it mounted!
Old 11-01-2007, 08:42 PM
ejoner's Avatar
Nice, that looks good, lol you cant really even see the "pmsuspension"
Old 11-01-2007, 09:09 PM
EG-Honda's Avatar
Default Re: Rear Lower Tie Bar - Finally got it mounted!!! Check it out! (ejoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner &raquo;</TD></TR><TR><TD CLASS="quote">Nice, that looks good, lol you cant really even see the "pmsuspension"</TD></TR></TABLE>
Yeah, but I would rather it hug the curve of the subframe then over hang it just for a place to put a logo (like some braces).
Cody08
05-01-2018 09:28 AM
Rodzknight
11-18-2006 05:08 PM
toguemaster
04-25-2006 04:33 PM
SCCAsean
03-23-2006 12:14 AM
^Sammy]!.
02-07-2004 08:15 AM
Quick Reply: Rear Lower Tie Bar - Finally got it mounted!!! Check it out!
