confused
confused
When i read on search it says use the blue wire on dizzy for tachometer.
In this picture does it mean #9 on OBD1 diagram?
https://honda-tech.com/attachment.ph...1&d=1265671659
Just want to clarify before i go hackjob on anything
Thank you guys!
Thank you guys!
Re: confused
Deleted cause The blue wire didnt make the tach work >< I have a auto cluster also which is frustrating..g
Re: confused
well the guy i bought my car from had a 3 inch pod tach wired to the #1 position of the dizzy and it floats and doesnt work, i wired it into that blue wire tonight and it didnt work. so im somewhat confused even more...
Re: confused
shoot for the blue wire on the dizzy and no where else. if the tach isn't doing anything you might want to make sure the power is hooked up correctly. if thats all well and good then the tach might be bad.
Re: confused
I actually last night cut all the wires and reinstalled the tach, it works fine except for i spliced into the wrong wire off the cluster for the backlight. otherwise i was very happy to have finally got it fixed. the person i got it from had it wired so hokey, it was rather a mess to clean up the wires and such, i even found some burnt wires i had to fix under the dash. damn russian rebuilds >< no offence but its what i get for not knowing what i was getting into.
Re: confused
Re: confused
Thank you! Its been a project. Next im saving for new bumpers and paint, getting rid of the kit its got on it, been a fiberglass pain in my a$$. I am still getting used to a 5inch below stock car and about two weeks ago I re-cracked the front bumper and had to fiberglue it together and retouch up with paint, at least its an electron pearl blue paint so it was easy to match color...at least i think its EPB, the touch up is barely lighter, i attributed that to weather. for it being barely deeper.
