Odd accleration problem
The last two days I've noticed that sometimes when I'm in 4th gear despite having the pedal to the floor my car can only maintain speed but can't accelerate. If I down shift to 4th its ok. Its not constant but seems to come and go. After the last time it happened I could smell a "bad" gas smell. BTW is an EG hatch.
Re: Odd accleration problem
well your bad smeel is most likely your catalytic converter. thats that mine was. now as far as the fourth gear thing ya got to keep in mind that if its stock in 4th gear it doesnt have the low end to push it further. thats why you have to down shift. i had the same problem with my 4 dr and its just it doesnt have the trouqe to go faster in 4th gear
check your o2 sensor. Mine on my accord just started messin around like that and I changed it problem went away. Hah I just read you said up hill. well if your car is stock 5th gear is useless on hills.
Is there a way to check if the O2 sensor is bad without replacing? No CELs right now.
if there isnt any cels then i dont see it being the o2 but to check you unplug it from the harness and do a resistance test. youll have to look that up i dont know what its sappouse to be off the top of my head
Hmm...ok so probably not O2 sensor then, car has no CELs, motor is all stock except for AEM CAI, the problem just started two days ago, really don't understand what could be wrong. Anyone else?
