d16y7 Misfire - out of ideas.
just picked up a 98 cx hatchback all stock (d16y7) with 105,000 miles on it. seems to be a very well maintained vehicle - valve train looks extremely clean, no leaks from anything. had a MIL and miss fire when i bought it and figured it was a simple ignition problem. i did notice that the fuel filter, primary o2, plugs, wires, coil where changed almost as if somebody was throwing parts at the car to fix it. I hooked up a scanner and 5 codes popped up - cyl. miss #1-4 and the random cyl. misfire. the miss is really only noticeable at idle and it isnt a dead miss. its fairly random. i had a bad feeling about the dizzy so i just bought a whole new complete after trying a cap, rotor, and ignitor. then put NGK plugs and wires in as well. the NGK's i pulled out all looked uniform and a greyish white color as they should be. the MIL has now turned it self off but the miss is still there. any ideas?
Re: d16y7 Misfire - out of ideas.
ohh yeah - i did check fuel pressure wich was about 34 psi. i also checked the fuel for contamination and alcohol% as well wich checked out to be ok. still a bit of winter blend gas but nothing that should cause this miss.
****, i been having that same problem, and i been changing parts
and parts and still the same, hopefully somebody comes with a useful idea.
another thing i been having, (not sure if you do too), is that my 3rd wire
from the dizzy has very litle spark unlike the other wires even after
trying a new set.
trying a new set.
have you checked timing has timing belt been replaces 100,000 is about the time it should be replaced
if the timing is too far off but not completely off, it will fire too early or to late causing random missfires and rough idle...
while you have the cover off you can check the crank sensor
well i did pop the Timing belt cover off and it seems that the belt has been changed, i couldn't get the belt to stop with the brand name to face up to see what it says, but i do know that it has yellow ink on it - didn't think OEM Honda belts had yellow on them. the belt seemed to be in good shape and tension. As for the CKP - i just put a brand new complete dizzy on it so that should be good.
damn timing belt was a tooth off. well as the saying goes, we all know what happens when we assume... thanks guys!
kamikazi_racing
12
03-08-2011 12:35 PM
