strange lean issue, thinking map or tps..
ok so i just put back in my basically stock d15 for a little and it ran fine at first. i had tuned it a little on crome and then one day when i step on it and only when i hit100% throttle my wideband will go all the way lean. thinking it was my tune i adjusted the tables and still no luck, so i swapped out the chipped computer for a completely stock ecu. still does same thing. runs fine around town but when i step on it it goes super lean but on decel it does cut the injectors which makes me think the map is working... any help would be great thanks
Re: strange lean issue, thinking map or tps..
sad when no one even knows the answer to a real tech question. i bet if i asked how much hp my make believe set up would have id have 30 replys by now
You would probably have better luck in the Tech forum. When is the last time your WBO2 was calibrated? Can you disable closed-loop and see if it still goes lean? Also, how lean are we talking? 14:1? does it go lean and just stay there or does it slowly get richer? Exhaust leaks?
i try and help ppl with their probs their having with their cars but everyone wants to argue with me so i dont help as much, did you take the neg cable off the battery when you swaped ecu's?
no didnt unplug the neg when i swapped ecu's but i dont see how that matters... and it does real right at 14.7 around town sometimes lower 14 to 15's but thats normal for closed loop. but as soon as i floor it it will dip quick to 12ish and then go straight to 20...
just an update... i put on my after market regulator and to get it to idle at 14.7 it had to be at 80psi.
id check the operation of the tps because it provides input to ecu so that when you abrubtly open the throttle the injector pulses are abrubtly increased to provide the correct afr, kind of like an accelerator pump on carburetors
i would say map sensor it works in conjuntion to obtain fuel map
check tps by hooking a volt meter to the 5v wire of the 3 wires ( i think middle iirc)
it should read do when warm
.5v at idle
2.5 at 1/2 throttle
5 v at WOT
does not have to be under load
.5v at idle
2.5 at 1/2 throttle
5 v at WOT
