ZC swap
ZC swap
This might be a noobish question, but I need help with a swap that I might be doing. So, I am planning on doing a zc swap into my 92 civic hatch cx. The motor is coming with intake and exhaust manifold, injectors, fuel rail, throttle body, alternator, distributor, tranny, and ecu. Would I need to get shift linkage, axles, engine harness, and starter or can I just use the ones I already have on the car? Thanks in advance. Also, if I have anything wrong, please let me know.
Re: ZC swap
well think of it this way the real difference that the zc has to the D16 vtec is the head. last time i knew they had the same axles the same tranny and same linkages. just to check to a search on the zc tranny's number and compare it to the one you have. if they are the same then you dont need to do axles or tranny. as far as the shift linkage goes that is a tranny thing. so im gunna have to say you wont need different linkages, starter part is a tranny thing too.
hope it helped
hope it helped
Tippyman
01-28-2006 06:42 PM
