H22a swap into 95 Civic tranny mount question
H22a swap into 95 Civic innovative tranny mount question
I am installing an h22a into a 95 civic and I am using innovative mounts, I have the existing bracket drilled out and taken off but I was wondering if anyone has any pictures or knows a build thread or anything with someone installing this new mount bracket so that I can make sure it is aligned properly.
Re: H22a swap into 95 Civic tranny mount question
Well, I recently installed the h22 innovative mounts on my eg, and what you need to do is to locate two holes on the bottom of the frame where the bracket would be installed, and line them up with the bottom holes on the innovative mount bracket. Then mark where to drill on top and drill away.
I wish I can take some pics of the bracket installed, but I don't have the time right now.
But just try to line up those bottom holes and you'll see what I'm talking about.
I did have to play around with the motor to line up the mounts on the bracket correctly (esp the rear mount) but eventually managed to install them. It wasn't too bad and the fitment was decent.
Hope it helps.. GL.
Hope it helps.. GL.
AVID mounts FTW when i had my h22eg coupe did not have to drill/cut off a mount location just had to redrill a hile in stock mount bracket alined perfect
Thanks, i called them earlier and thats what they told me i got it now, i had some other mounts when I installed an h22 in my integra but i like this new tranny mount bracket much better than the others
XkjeldorX
06-21-2006 01:49 PM
