1994 civic h/b ls swap axle problem
i have a eg with a ls swap i recently had the outer cv joint on the axle pull apart, i replaced the entire outer shaft only for the same thing to happen to the new one no more than a day later, the car still drives as it is not completely pulled apart but when i am on the gas above about 50mph the car vibrates, the last axle i had in lasted since the swap was put in almost 2 years ago, the motor mounts are good as are the ball joints im at a loss thanks for your help.
Re: 1994 civic h/b ls swap axle problem
I'm trying to figure out what axles i'll need for my car. I have a 94 civic dx and i want to do a h22 type s swap. I'm trying to learn as much as i can and i'm usually asking my buddy tons of questions. I've looked online and have found so many different types that i have no idea.
thanks
thanks
