white smoke problems????
Old 05-12-2010, 08:20 PM
tony_yang's Avatar
Icon2 white smoke problems????
Hey everyone, I really need some help. I just bought a 99 civic si turbo that is built. (block) Every morning when I start up the car, there isn't any white smoke coming out of the exhaust for the first minute, but then it smokes very bad. Its like a jet stream of white smoke. But when I drive the car for 15 minutes, the jet stream white smoke goes away. There isn't any leak between the head and block. I took it in to a performance shop, to do a leak down test. Everything came back positive, motor's healthy but running very lean, thats what they told me. My buddy and I did a compression test on all cylinder and its all at 185psi on all cylinder. please, please, please help me out, I don't want to waste anymore time, and figure whats the true problem. Could be the head gasket?
Last edited by tony_yang; 05-12-2010 at 09:31 PM. Reason: need to add some sentences.
Old 05-12-2010, 08:29 PM
D16SiHatch's Avatar
Default Re: white smoke problems????
well white smoke is coolant. so it's either the headgasket or a crack in the head or sleeve.
Old 05-12-2010, 09:36 PM
EG-SIXV-TEC's Avatar
maybe cracked...
Old 05-12-2010, 10:11 PM
saltybeagle's Avatar
def coolant... coming from somewhere... sounds like an intermitant problem... i would start with head gasket and go from there....
Old 05-12-2010, 11:12 PM
Pr0j3cT95dX's Avatar
I definitely agree with everyone above. Try checking your head gasket first then work your from there
Old 05-13-2010, 04:14 AM
00siblue's Avatar
only checks
-check your oil if it looks milky you got a head gasket problem
-if your car gets to operating temp then starts to smoke you may have a cracked head
-bypass all the hoses that run to the manifold
-the gasket on the intake manifold
-your manifold could be cracked...possible
Old 05-13-2010, 07:18 AM
tony_yang's Avatar
thanks for all the response. I'll take it apart this weekend to see whats going on.
alswizzo
01-24-2013 05:27 PM
curtiss_robinson
01-11-2009 06:46 PM
project ak
07-28-2006 03:00 AM
jdmtim
11-20-2003 01:43 PM
Randomlude
10-12-2002 03:56 PM
Quick Reply: white smoke problems????
