need some help
need some help
ok i have a check engine light code 43 fuel supply
upon start up there is no check engine light only after you drive the car for 15 min does the check engine light come on, once you turn the car off it takes another 15 min for the check engine light to re-appear
i have tried to replace many things to fix this code all the items that were replaced came from a donor vehicle that had no check engine codes what so ever
items replaced
1. o2 sensor
2. fuel filter
3. fuel pump
4. main relay
5. ecu
6. injectors
7. fpr
8. gas cap
car is a 93 hatch obd1 b18b1 swap
items replaced
1. o2 sensor
2. fuel filter
3. fuel pump
4. main relay
5. ecu
6. injectors
7. fpr
8. gas cap
Re: need some help
the smog guy told me that there could be a pressure leak in the tank or in the lines to the charcoal canister. maybe you can get one and try it...like one off a friends car so you dont have to pay 175 bucks for a new one without knowing. my 43 code was the gas cap. but try using a friends canister if you can.
drkns
07-21-2006 09:11 PM
