crazy idle problem
crazy idle problem
crazy idle problem
car is a 95 civic used to be auto with b20b n gsr tranny
problem
when car is cold idles at like 500-700 rpms feel like is gonna die proble stops when car is hot, started doing this like 2 months ago was fine before
already changed cap rotor spark plugs spark plug wires fuel filter
already messed with IAC and the fast idle control valve..
throwin cel 10 bu didnt had it before when it was running fine but i got it now n still doing same
what other sensors or whats else can i check for
any help would be appreciate it
thanks for lookin and takin ur time
problem
Re: crazy idle problem
Cel 10-intake air temperature sensor. Try purging your coolant system to rid the bubbles that might be learkin. Otherwise try to clean the Ish out of the Iac
Those intake air temp sensors are flimsy!
Sounds like the FITV has to be threaded out a little bit. If you screwed in the FITV (you said messed with it) then maybe you screwed it in too much.
EK_MaGz88
03-21-2011 06:32 PM
F'NfastSOHCturbo
02-27-2007 11:33 PM
Loveless
03-24-2003 09:02 PM
