ELD code 20 help
Old May 10, 2010 | 09:07 AM
jdmh22eg2's Avatar
Default ELD code 20 help
ok guys i have already read some of the other (obd1) code 20(electrical load dectector) threads and i have changed my under hood fuse box to a WORKING one and still got the code
any other idea's
car is a STOCK STOCK eg Si 94
Old May 10, 2010 | 03:07 PM
jdmh22eg2's Avatar
Default Re: ELD code 20 help
anyone
Old May 10, 2010 | 03:50 PM
jdmh22eg2's Avatar
come on need info
Old May 10, 2010 | 06:08 PM
jdmh22eg2's Avatar
Old May 10, 2010 | 06:19 PM
shogee's Avatar
check the alternator output that might be an issue?
Old May 10, 2010 | 06:20 PM
shogee's Avatar
i don't quite remember but you are sure the eld is in the fuse box
Old May 10, 2010 | 06:30 PM
jdmh22eg2's Avatar
^ well acording to the honda service tech guy i know and all the threads i read on here says it is and alt is same one that i had in car on previous motor
and the wierd thing is that i dont have any charging battery/ starting issues just want to make sure wont cause other issues/ and dont like having CEL's
Old May 10, 2010 | 06:39 PM
shogee's Avatar
yea but i think that if the alt is not putting out voltage like it used to it might trick the ecu to throwing the could, because i believe the eld only measures system voltage and is a sensor input for idle speed. i could be wrong though. but yea the alt might just be providing enough volts for charging, or maybe i'm just going somewhere way off, but at least thats a start.
Old May 10, 2010 | 06:42 PM
jdmh22eg2's Avatar
yea idk will c what other ppl think thanks for any info tho
Old May 10, 2010 | 06:43 PM
shogee's Avatar
here is a good link to how eld works
http://www.civicforums.com/forums/21...-detector.html
Old May 10, 2010 | 06:54 PM
jdmh22eg2's Avatar
yea my fuse box does not have a piece like that it is built into the underhood fuse box that is why ppl say to change when u get the code and i did and still nothing
and i dont have ANY aftermarket audio in my car
Old May 10, 2010 | 08:41 PM
jdmh22eg2's Avatar
ttt
Old May 11, 2010 | 09:40 AM
shogee's Avatar
you should still check the alt output
usdm_ED7
Jun 26, 2012 01:47 PM
usdm_ED7
Aug 30, 2011 09:30 AM
jdmh22eg2
Jun 3, 2010 04:45 PM
tubed-ef
Oct 18, 2008 08:22 AM
