Barely failed emissions, any input on the cause
Carpe diem!
Car is a 1992 honda civic si, has a JDM D16a on stock d16z6 p28.
has new cat converter, spark plugs etc,
standard
HC 1.89 1.00
Carbon monoxide 12.88 12.00
NOX 1.96 2.50
standard
HC 1.89 1.00
NOX 1.96 2.50
Re: Barely failed emissions, any input on the cause
Any CEL codes? It's running rich.
Things to look at:
-Plugs, wires, cap, rotor
-Ignition timing
-Thermostat stuck open
-ECT and O2 sensors
Things to look at:
-Ignition timing
-ECT and O2 sensors
Carpe diem!
Do you have recommended NGK plugs installed?
How old are the wires, cap, and rotor? Have you inspected/tested them?
Is the ignition timing set to spec?
How new is the Cat? If its Brand spanking new you gotta break it in or you'll get a false reading. Supposed to drive around for a good 30-40 miles and when you retake your test, make sure you drive for 20 minutes to get it nice and warmed up. Try that and see if it works out, if not i'd do what everyone said.
Carpe diem!
the wires, cap and rotor came with the jdm motor lol, so I don't know how old they are, I bought the motor about 2 months ago from hmotors. I'm gonna check the timing tomorrow, need to buy a timing light.
flatblacksleeper
16
04-12-2009 05:46 PM
bossman032
101
04-20-2004 06:45 PM
02, az, barely, carbon, emission, emissions, failed, failing, monoxide, motorcycle, stuck, thermostar, to, troubleshooting
