removing fender on 98 coupe
anyone have pics or some guides? i removed the 3 bolts on top and got 1 from the door area. it got too dark out and couldn't see anything else. i'm assuming I have to remove the wheel liner. are they screws or fasteners? how do I remove fasteners? are there any other bolts to remove?
Re: removing fender on 98 coupe
you need to remove your side skirts because they are 2 bolts holding the fenders and also need to unbolt your front bumper because there is 1 more by where the headlight is.
get the 3 under your hood....theres one or 2 rite behind your sideskirt..one in the door area...and i think one more you can get by the wheel...attatched to your bumper..
ok i didn't know about removing the skirt. is there any difficulty in that? i saw the one on the bumper at the end of my escapade. noted.
theres still one behind bumper, headlight bolts to it.
Side skirt is a bitch for me at least, i yank on it a few times and it pop enough for me to get the bolts.
there are 2 screw type clips under side skirt going into the car, remove those, it will make it a bit easier to get off. You dont need to fully remove it from the car just enought to get bolts out and in.
remove the push pins under the sideskirt and slide it towards the front of the car....make sure you take the inner fender out before you try to slide it forward
thanks. i was planning on doing it today, but am feeling a little under the weather. i'll get to it this week.
WIb16crxWI
05-10-2006 12:07 PM
hondamonkey
22
04-19-2006 09:49 AM
