Sudden noticable gas mileage drop ('00 Civic EX)
My 2000 Civic EX (AT, 96K) seems to have suffered from a noticeable decline in gas mileage for no apparent reason. I was due for an oil change, but it had never happened before because my oil was so bad (I change it myself every 4k and use synthetic). I was averaging about 27 Combined (probably about 65/35 highway to city on a normal tank) and that has dropped to almost 22.
No clue why.
Also threw a new air filter in when I changed the oil yesterday (had been about 10k).
Has anyone else experienced this?
No clue why.
Re: Sudden noticable gas mileage drop ('00 Civic EX)
No codes.
Plugs, wires were changed about 17k ago. Not sure about cap and rotor.
Not sure about the last one? Had the TBelt replaced at a reputable Honda dealer in town, so I'd assume so.
Definitely inspect the contact points of the cap and rotor for wear and corrosion. If they are old, just replace them with OEM parts.
As the plugs have almost 20K miles on them, inspect and/or replace them too. They're cheap.
You may be able to get a free rental on a timing gun at an auto parts store.
I just want to share my experience with the same issue.
I was recently troubleshooting a problem with my Civic EX 1997 (D16Y8) and ended up replacing the distributor cap, rotor and ignition coil (Part# TC-08A). I bought only cheap parts from Napa. 4 full gas tank after the switch, my gas milage dropped from 34-38 MPG to 25-28 MPG!!!!! 30% drop!!!!
I decided to test whether the new ignition coil (Napa Echlin 1101017A RUF89CS RA0111) was the culprit and put the old one back (TEC Honda OEM). I also reset the ECM/PCM.
Problem solved! Got back to my 35+ MPG.
CONCLUSION: as RonJ@HT said, OEM only!
Other stuff to check out:
Temperature stable after a 5-10 min drive? If not it could be a stuck open thermostat.
PCV: Test the PCV and replace if necessary.
No clue why.
No clue why.
If he hasn't replaced the PCV valve or can't remember when he last replaced it, he needs to replace it..
runtohell121
70
08-05-2014 11:08 AM
zenon8890
11-16-2012 02:33 AM
ctownintegra
01-20-2010 07:26 AM
