Rear disc conversion
Hey all, i have a 00 ex ek coupe with the factory rear drums, my question is that i mite get a rear disc setup but the guy says its fro a 94-01 integra and it will only work with 92-95 eg models, suppose to consist of the lca,rotor,caliper and lines and cables.... would any one know what else i would need?
Re: Rear disc conversion
You can use it, however, all you need to use is the trailing arm, of corse the breaks.
Keep all control arms and shocks, from your car. Get 99-00 si E break lines, and i think integra break lines are different from 96-00s not sure.
Also your going to want to get a 96-00 civic dx, coupe or hatch, hx, cx or 99-00 si prop valve. And keep your master cyl.
i used DC trailing arms on my EK. sounds like all the parts are there. check the bushings to see if cracked. if so, get a new set.
Chefskinny
04-15-2015 05:48 PM
powerslide360
03-20-2005 07:30 PM
VisualEcstasy
17
03-28-2003 01:16 PM
