d16z6 into a VX, turns over WONT FIRE!?! Help??
Okay, I just swapped a d16z6 into my 92 VX hatch..I've got everything hooked up, went to start it ,and it'll turn over but wont fire...I don't hear my fuel pump kick on (but the motor is getting fuel, because I pulled an injector to test it) and I am also not getting a spark, (however I have 12.1 volts to my distributor), I have kept all my original VX wiring and harnesses, and just switched out to the z6 motor, and ECU. I have read things about 02 wiring, but would this keep it from running? Any help would be greatly appreciated, as I've started replacing other parts thinking this could be the issue, only to have no luck, and its really starting to add up. Thanks in advance!
Re: d16z6 into a VX, turns over WONT FIRE!?! Help??
I looked for it and couldnt see anything? is it underneath? I just tried running a ground from the thermostat itself to the ground on the battery and it still wouldnt fire...any other suggestions?
Thanks a ton guys, I'll let you know what I find tomorrow when I look at it again...hopefully I can get it to finally start! (wires are brand new, thanks for the suggestion though!)
