ls motor into eg 4 door rear mount question
Old 06-13-2010, 10:58 AM
jthrasher1's Avatar
Default ls motor into eg 4 door rear mount question
my brother got a ls motor for his 4 door eg civic and the motor is mounted in it the 2 side mounts work fine but the rear t bracket or l bracket ware its supose to bolt to the motor is about 2 inches away is there a mount he can buy to solve the problem or does it have to be cutom thanks....
Old 06-13-2010, 11:10 AM
jayWknight's Avatar
Default Re: ls motor into eg 4 door rear mount question
this is a manual swap correct? If so you need a rear t-bracket from a 94-01 integra. Doesnt matter if it is ls,rs,gs or gsr, all the same.
Old 06-13-2010, 11:20 AM
jthrasher1's Avatar
yea its a 5 speed swap so 94-01 integra rear t bracket thanks for the info
Old 06-13-2010, 11:24 AM
jthrasher1's Avatar
well my bad i just talked to my brother and he has that t bracket so must be somthing else wrong.. and also its gotta go the right about and inch to so
Old 06-13-2010, 06:25 PM
Gunmetal_B20_Hatch's Avatar
He has the wrong bracket... Plain and simple.
Old 06-13-2010, 07:13 PM
T Thrash 09's Avatar
well im his bro and the motors a b18b1 if it matters and the t bracket is off an ls this motor came sraight out of my buddys ek coupe and has a drivers ls mount and eg passenger mount the motor its self sits in the bay perfect it just that bracket needs to be over about two inchs i will take pics tomorrow to show what i mean.all help is apresiated - thanks
Old 06-13-2010, 07:18 PM
Andrew14's Avatar
hey, by chance after your done with your ls swap in the eg sedan, could you tell me how much of a difference you feel compared to the single cam, because i also want to do this swap to my eg sedan. Thanks!
Old 06-13-2010, 08:08 PM
Thats the problem... It came from an EK chassis. You need an Integra mount as stated before.
cereeb4
09-07-2006 03:43 PM
Hatchd
06-22-2005 04:08 PM
BLUE EH3
12-09-2003 09:08 AM
Quick Reply: ls motor into eg 4 door rear mount question
