Questions about s2000 cluster in 96 civic
Well my s2000 cluster just came in and I put power to the cluster to make sure the cluster is in working order. My friend has a s2000 cluster in his 92 kseries civic and his temp doesn't work and neither does his speedometer. My question is will mine not work aswell ? I did some research and read that someone made a vss convertor box which fixed the speedo problem, is this correct where can I find one?
Re: Questions about s2000 cluster in 96 civic
Correct. I'm not completely sure on all the names - but I believe the speedohealer v4 is what you need for the speedometer, and something like modifry? for the temperature.
You will probably get a lot of "search!" responses, and rightfully so... I found this the other day with ease.
tacosandbeans
06-18-2010 06:38 PM
