b16 clutch on b20 motor with b16 tranny
hey will everything bolt up if i have....
aftermarket exedy clutch/flywheel for b16a
b16a transmission
b20 block/crank
thanks a lot.
b16a transmission
b20 block/crank
thanks a lot.
Re: b16 clutch on b20 motor with b16 tranny
i hope you're right.
i was just thinkin because the flywheel clutch bolt to the crank, which is a different size on a b20 than on a b16...... oh noes.
but the weed tends to make me paranoid
Flywheel bolts should be the same. Unless you picked up a B20 that had an automatic transmission.
AT bolts are shorter than MT.
PS: Please don't smoke while working on your car .
