Idle Problem with my GSR Hatchback...
Every once in a while I will have some idel complications. It will idle up and down between around 500-1200. Anyone know why exactly? Throttle Positioning Sensor? If so How do I fix it. It only does it once in a while, So it can't be timing can it? Any help would be great;y appreciated...
Re: Idle Problem with my GSR Hatchback... (PDXHatchback)
check your vac lines for any leakes
check to see if throttle cable is loose
try tightening the TB screw
could be your iacv
could be your iacv
