Help!!!!!!!!Engine idel
Old 11-15-2003, 08:25 PM
Thundersquid's Avatar
Default Help!!!!!!!!Engine idel
My JDM B16A idel is bogging, idel would drop and shoot back up and engine would shake very severe. I recently replace the motor mount with Energy Suspension bushing. Would that shake the car like I have describe? I change idel control, but still nothing. I also replace the wire harness because the old one was kind of Mickey Mouse wire up. I swap the ECU with a GSR but no effect. The only thing left is my O2 sensor need to be extend to the header. The question is can the car run w/out O2 sensor. With out it, what is the effect? Any one have experience this problem?
Old 11-15-2003, 08:27 PM
Default Re: Help!!!!!!!!Engine idel (Thundersquid)
Old 11-15-2003, 08:28 PM
SLeePeR012's Avatar
A lot of people have this problem, and there are different reasons behind it.
Mine was the IAVC.
Take it off, I believe its only 2 10mm from the back of the manifold and take off the 2 coolant lines under it. Clean out the 2 screens you see mine was so dirty.
Try it out.
Old 11-16-2003, 06:20 PM
MrEg's Avatar
Default Re: Help!!!!!!!!Engine idel (SLeePeR012)
i think its the IAVC..... clean it out.....seen 2 cars with the same prob....
good luck
Old 11-16-2003, 08:30 PM
Multi-paradigm
Good ol' Screwtape's Avatar
Default Re: Help!!!!!!!!Engine idel (mr_timluu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_timluu &raquo;</TD></TR><TR><TD CLASS="quote">i think its the IAVC..... clean it out.....seen 2 cars with the same prob....
good luck</TD></TR></TABLE>
You guys mean the IACV, right? As in...Idle Air Control Valve.
But yeah, like he said...take it out and clean in. It bolts onto the back of the throttle body.
But before you do all that, are you showing any CELs? Check the code. That'll tell you for sure.
But I'm putting my money on the IACV.
1999AZhatch
11
06-11-2018 02:33 PM
sohc_ef2
09-29-2012 05:34 PM
SlippylesKB
08-03-2003 12:32 PM
FUP23
08-16-2002 08:16 AM
1fstevo
10-30-2001 10:13 PM
Quick Reply: Help!!!!!!!!Engine idel
