Grinding noise....help =/
There is this grinding noise coming from the middle of engine right under the IM so it seems. This grinding noise only happens when im at 4000RPM in each gear. Can anyone help me fix this?
Re: Grinding noise....help =/ (jwn7)
I don't know, but it sounds real nasty. Its sounds more like that machine you use when you sharpen your knives if they are dull. You know what im talking about?
Re: Grinding noise....help =/ (00 Hatch DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 Hatch DX »</TD></TR><TR><TD CLASS="quote">I don't know, but it sounds real nasty. Its sounds more like that machine you use when you sharpen your knives if they are dull. You know what im talking about?</TD></TR></TABLE>
yeah i know.. mine makes the same nasty kinda "ARRARRRRAAARRRAARRAR" noise at 3000. i bet you 20 bucks it's a loose heatshield or something else loose on your exhaust.
odd, why only at 4K though? Could it be something from the motor?
-I don't think its from the exhaust headshield, cause it happened on my brother's car too.
at 4k your engine's sound is probably just oscillating at the only possible level which causes a resonance with whatever it is making the ARRRRARARRARARAR noise.
So I shouldn't be worried about anything then huh?
-Now that I think of it, it definately sounds like a ******* SAW chopping some wood
i wouldn't take my word for it... i'm kind of an eternal noob. id have a look under your car with someone holding the tach at 4. you should be able to hear it pretty well under the car.
also did this just start recently... like when it started to get cold? cause my car just started to make this kind of noise a few weeks ago with the advent of the cold - only thing is mine is at 3k not 4.
it's been making this sound for awhile now, at least a year.
-ah, come on honda-tech guru's, I don't want to keep driving like this if i'm messing something up real bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 Hatch DX »</TD></TR><TR><TD CLASS="quote">it's been making this sound for awhile now, at least a year.
If its been that long you've prolly already messed up whats gonna be messed up, my friends Teg had a noise from his heat sheild only at like 4K and up, try tightening it down or something its worth a shot.
