Replacing the Throw out Bearing
Hey guys, how do i change the throw out bearing? i got a new clutch and pressure plate, and a new throwout bearing, but im wondering where it goes. if anyone has any pics or write-ups for clutch replacement that would be great. thanks
Re: Replacing the Throw out Bearing (invboost)
where do you think it goes.... you have to seperate the engine and transmission - not really that hard, but a very involved process. if you want to do it yourself i suggest you get a helms manual. if you dont know what your doing, you would be much better off letting someone else do it.
Re: Replacing the Throw out Bearing (jwn7)
so then it is noticable when i take the clutch off? im getting a helms tomorrow, i was just trying to get some insite before hand. anyone have any pictures?
Re: Replacing the Throw out Bearing (BI8B)
When you separate the tranny from the engine, it will rest around the spindle that goes into your clutch disk! It's a good thing to replace when installing a new clutch/flywheel.... So good job! When re-installing, be sure to put a minimum amount of grease/lube around the inner portion of the bearing that rests on the spindle, This will ease it's break in!
