best flywheel
Re: best flywheel (spoondek)
Toda makes a very nice flywheel. They centered the weight on the flywheel for a more balanced piece. Check the sponsors forum for toda products.
Re: (THEINTEGRATION)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEINTEGRATION »</TD></TR><TR><TD CLASS="quote">Toda, Jun, Z-Speed...
Are you looking for a clutch in terms of weight or strength?</TD></TR></TABLE>
well cant it be for both not just one?
Re: (spoondek)
You are also looking at spending a fortune for these setups. Good Luck and I hope that you make alot of money, because you are going to need it.
Still nice pieces though.....
Running a 8.8lbs ACT prolite, love it.
What you need to do though is let people know your application. Drag, street, autox, roadcourse etc...
Re: (spoondek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoondek »</TD></TR><TR><TD CLASS="quote">well cant it be for both not just one?</TD></TR></TABLE>
Toda, lightweight,balanced, and pretty strong (as already mentioned above). Look for a flywheel made of chomoly steel, not aluminum if you want something light and strong. Or if you want a whole clutch look at exedy brand.
weren't there issues with the starter and stuff with jun, toda or spoon flywheels??? i can't remember for certain but can someone look into this?
Moderator
Re: best flywheel (acydphryck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acydphryck »</TD></TR><TR><TD CLASS="quote">weren't there issues with the starter and stuff with jun, toda or spoon flywheels??? i can't remember for certain but can someone look into this?</TD></TR></TABLE>
those issues were with the clutchmasters flywheel made by fidanza.....i know i personally installed one!
Jun did have this problem.
Re: (-CivicTuner-)
Depends on what you want personally. Keep in mind that stock flywheels are heavier and it takes a bit longer for you to rev up. Whereas a lighter flywheel will give you a bit more in acceleration because you can rev up faster.
Mr.Integra
01-22-2004 06:24 AM
