Crazy ECU Code
Crazy ECU Code
Ok heres the deal, I have a Spoon P30, im throwin a 36??? i have never heard of a code 36, if anybody has any ideas let me Know. Thanks
Re: Crazy ECU Code (slammed_93_hatch)
i know it wont help you much but here is a list of ecu codes. it doesnt have 36 listed. GL to you bro
http://hondata.com/techecucodes.html
Re: Crazy ECU Code (TheLabEG6)
Usually the code 36 comes from something like a P13 ECU that uses 4WS steering. The smaller plug with the blue/white wires is the for the 4WS and is usually not found on a B-series ECU. Are you sure you're reading the CEL correctly?
Re: Crazy ECU Code (Newman)
code 36 is for the TCS as in Traction control system, found on some EG9 SiRs. Definatly a valid code.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">
Usually the code 36 comes from something like a P13 ECU that uses 4WS steering. The smaller plug with the blue/white wires is the for the 4WS and is usually not found on a B-series ECU. Are you sure you're reading the CEL correctly?</TD></TR></TABLE>
above is also a example not so much of 4WS but 4th plug which is used for TCS on the BB Preludes. Its even outlined in the Fields instructions
slowpokecivic
02-20-2007 04:59 PM
