00si rear discs on 92cx?(rear disc conversion, e-brake cables)
Sorry about the funny title, just a late night thought that if we
made them(the titles) more discriptive it would be a lot less easyier
to search.
In the mean time, while im trying to find the answer in the
search, please help me out. Or you could help me search.
99si rear discs are going to be put on my 92cx. Im thinking
they will bolt up fine, but im also thinking that I will need to
get new ebrake cables right? If so, what models will work?
to search.
TSPeed Factory
Re: 00si rear discs on 92cx?(rear disc conversion, e-brake cables) (3lw(.)(.)d)
you will have to get the e-brake cables for the 92-95 civic si, or ex with rear disc brakes.
Re: (JMU1337)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMU1337 »</TD></TR><TR><TD CLASS="quote">That is why you research this stuff before starting little projects such as this </TD></TR></TABLE>
who said I already started?
this is my research.
Re: (stripes777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stripes777 »</TD></TR><TR><TD CLASS="quote">hey , how much did u spend so far to get the rear brakes of the si? i wanna add rear brakes too, maybe even change the front to some gsr brakes. thanks</TD></TR></TABLE>
Long story short, ill end up making money off of them. I don't spend
much money on my car.
Re: (elwood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwood »</TD></TR><TR><TD CLASS="quote">
much money on my car. </TD></TR></TABLE>
anyways, back to the point.
Why wont they work? Too long, too short? Whats
the deal?
the deal?
Re: (elwood)
Not to jack your thread or anything, But What about a 89 integra e brake cable with rear disc? Going onto a 95 ex with rear drums. Converting to rear disc.
Re: 00si rear discs on 92cx?(rear disc conversion, e-brake cables) (elwood)
it won't work you have to use get gs-r cable or si e brake cables
Modified by airshifta at 12:32 AM 1/5/2004
Re: (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">Not to jack your thread or anything, But What about a 89 integra e brake cable with rear disc? Going onto a 95 ex with rear drums. Converting to rear disc.</TD></TR></TABLE>
From what most people say you need to get the cables that would come
on your chassis. But im wondering if thats really true. I would start on mine
but its going to be dark in about an hour and I have school in the morning.
Looks like I need 9, and 13. That will be about 90$, more then I want to spend.
but airshifta claims that his 99 gsr rear disc bolted up, and that they are
the same as a 00si, im hoping he's right. (crosses fingers)
Re: (elwood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwood »</TD></TR><TR><TD CLASS="quote">Anyone want to trade me? </TD></TR></TABLE>
Re: (elwood)
i dont see why it wouldn't work.. arent they the same as tegs? im sure you can use the stock ebrake cables.. it doesn't take more than an hour to get both bolted up and like 15 mins to bleed.. test it out first.. my rear brakes bolted up and the lines fit fine..
Re: (eli_vang)
It would help if you told us what the discs were from, and
what you put them on.
its 12 degrees out side and I dont have a garage, or any
pavement. It takes a good 20 min. to jack my car up.
Re: (Hype-aaaRRRR)
https://honda-tech.com/zerothread?id=152884
https://honda-tech.com/zerothread?id=641639
https://honda-tech.com/zerothread?id=667726
https://honda-tech.com/zerothread?id=632731
https://honda-tech.com/zerothread?id=626395
https://honda-tech.com/zerothread?id=604205
https://honda-tech.com/zerothread?id=607851
https://honda-tech.com/zerothread?id=507164
https://honda-tech.com/zerothread?id=480079
https://honda-tech.com/zerothread?id=459421
https://honda-tech.com/zerothread?id=431150
https://honda-tech.com/zerothread?id=406587
https://honda-tech.com/zerothread?id=388309
https://honda-tech.com/zerothread?id=372000
https://honda-tech.com/zerothread?id=48578
Search is your friend. also theres a big STICKY for FAQ's on the top of this forum. plenty of info there.
Solbros Owns Me
Re: (Hype-aaaRRRR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hype-aaaRRRR »</TD></TR><TR><TD CLASS="quote">anyone know if i can use 99-00 si rear disc swap and swap the si lca's for 98 and up itr lca's?</TD></TR></TABLE>
if you're talking about our 95 CIvic, then yes. 99-00 rear assemblies bolt right up on the EG, and the ITR LCA's are a direct replacement, along with the shocks
Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">
if you're talking about our 95 CIvic, then yes. 99-00 rear assemblies bolt right up on the EG, and the ITR LCA's are a direct replacement, along with the shocks</TD></TR></TABLE>
yes its a 95 civic...right now i have stock drums in back and itr rear lca's and itr rear konis...so im planning on swapping over 99-00 civic si rear complete disc setup but swapping the si lcas that come with the setup and putting on my itr lca's so i can keep my itr konis...so that will work fine correct? thanks
Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">it will work perfect. THe 99-00 LCA's won't work on the EG chassis if memory serves me correct anyway</TD></TR></TABLE>
aight cool man...thanks for the help...btw...im still working on my secret front setup...its going good
