is it even possible....?
....to get the crank pulley off? i have been torquing and smacking and swearing for more than an hour now, and it just keeps on slipping. so, guys, i need help getting my crank pulley untorqued..... why? i need to change my timing belt and driver's side mount bracket... i'm using a rubber strap wrench (that is slipping very slightly) and a 2.5' breaker bar...... any advice? thanks in advance.
Re: is it even possible....? (Chris y0!)
i wish... motor is sitting on the floor of my garage. would it be easier if i dropped it in the car before changing the belt?
Re: is it even possible....? (Team 4R)
what you need is a longer breaker bar for more leverage and a chain strap wrench. you should be able to rent the wrench from Autozone/Checkers/etc. and maybe more muscle.. do it before you put it back in the car.. it's a lot easier to get the timing on.. good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">put the car in gear... have somebody step on the brakes.</TD></TR></TABLE>
That or put a screwdriver through a hole in the flywheel.
well, tranny is coming off today too, so i will try the screwdriver-through-flywheel method first..... thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team 4R »</TD></TR><TR><TD CLASS="quote">well, tranny is coming off today too, so i will try the screwdriver-through-flywheel method first..... thanks.</TD></TR></TABLE>
or you could leave it on and do what Chris said, and stick a flat in the starter hole.
Solbros Owns Me
Re: is it even possible....? (O.G triple O.G)
don't use a flat head, use a close ended 14 mm Craftsman
OR, if the tranny is off....here's a very easy way....
pull off flywheel and bolts....put 2 bolts on opposite each other on the crank. Slide a 1x1 piece of angle iron between the 2 and pop the bolt off.
a 450 lbs impact gun couldn't get a pulley off one of my spare short blocks the other day, so I came up with this incredible idea, and it took 2 minutes
EG2Driver
06-15-2006 07:24 PM
stevescivic
07-23-2004 06:42 PM
dstahl01
17
02-28-2004 06:27 AM
