Let go of brake car dies...
Old 04-18-2013, 07:20 PM
Ekay's Avatar
Default Let go of brake car dies...
sup guys,
my friends car is messed up has a eg not to sure what year but..
the only way he is able to drive his car is when he presses down on the brake
and when we lets go of the brake his car dies..
hopefully we can find out whats wrong, we are both saying electrical...
please and thanks !!
Old 04-18-2013, 07:22 PM
B_Swapped93's Avatar
Default Re: Let go of brake car dies...
Originally Posted by Ekay
sup guys,
well the year and engine plus auto or manual are needed or else this could go anywhere. how can he drive with the brake on....unless you mean it can idle(run while stationary)
Old 04-18-2013, 07:30 PM
Ekay's Avatar
ooops my bad..
auto and he is barely pressing on it not to hard just enough to were hes able to drive it
Old 04-18-2013, 07:37 PM
ooops my bad..
gonna need new brake pads soon if he's doing that for any length of time. im going to assume it's a stock d16y7 car is prob 96+ is he getting any codes ?
Old 04-18-2013, 07:38 PM
Ekay's Avatar
its a EG, and yeah stock and no codes
Old 04-18-2013, 07:50 PM
xile6's Avatar
Z6/b7 manifold? Or the y7 manifold?
And that motor in that car on obd1 needs a tune.
But check for a vacuum leak in the brake booster.
Next check the iacv. It may just need a cleaning.
Old 04-18-2013, 08:03 PM
iacv won't do that and no it doesn't need a "'tune'" unless you mean tune up. So it's and obd1 with a what engine the y7 was obd2 only IIRC
Old 04-18-2013, 08:07 PM
hunan beef's Avatar
Assuming this is really "stock", this would be a d16z6 or d15b7. Not sure where everyone is getting Y7 from....
Does this happen only in Drive? or does it do it in Park and Neutral as well?
Do you hear any hissing coming from the engine?
Old 04-18-2013, 08:16 PM
mixed up EK with EG was my bad lol
Old 04-19-2013, 09:23 AM
xile6's Avatar
saw y7 and eg so thought swap. which a y7 on a p06/p28 will run funny.
but now that I see its a 92-95 b7/z6 I got a better undsr standing.
and iacv can causd it because breaks chabfe the load on the motor.
also had a bad cylinder on a car before and when u came to a stop it would die.
Old 04-20-2013, 03:50 AM
VPUPPY's Avatar
I'd test the brake booster and make sure it's not causing a vacuum leak like xile6 said. You def have a leak. Likely internal to the booster.
AnnaM
Honda Civic (2006 - 2015)
02-28-2022 05:16 AM
Robert17crv
Suspension & Brakes
11
11-02-2017 01:36 PM
logg_frogg
03-08-2008 02:58 PM
peanut butter
08-15-2007 05:57 AM
Quick Reply: Let go of brake car dies...
