d16z6 intake manifold fuel rail missing AEM fuel rail install?????
okay i got a used d16z6 intake manifold w/out fuel rail. nuts bolts, spacers fuel injectors.
i cleaned up the whole intake manifold painted it and put new o ring and sensors etc.
i already got an D series AEM fuel rail.
but im clue less on how it will bolt up if it needs any special spacers for it.
i also got a used d16 non vtec motor intake manifold w/injectors and fuel rail.i want to know if the fuel injectors/fuel rail from that thing will fit the d16z6 one.
and if i install the aem fuel rail how would i mount it w/ what size spacers???
Re: d16z6 intake manifold fuel rail missing AEM fuel rail install?????
The AEM rail will bolt up, but you might need fitting adapters for the fuel line and/or FPR. I don't know. You shouldn't need any spacers.
The D16Y7 (assuming that's the right motor) rail will work, but the injectors will not. They are smaller.
Son, is the D16Z6 a MPFI engine? Sorry for the retarded question. And is it batch fire, direct injection, whatever?
a y7,y5 or 78 fue; rail will fit a z6 .... the 96+ D series the rail has 2 holes as the z6 has 3... any d15 or d16 ......92-95 fuel rail will work
