Rear Susspension problem
Currently driving a 93 Eg; Whenever I make a sharp right or just a hard right turn i get some nasty wheel rub from the back left tire, also happens when I hit a hard bump. I dont get any other tire rub except from that tire.
I just installed knoi yellows and skunk2 springs. everything is done right but that problem still occurs still only on the one tire.
I have no clue what could be causing this, any help would be appreciated
Re: Rear Susspension problem
did you put new bushings on the top hats of the struts? did a similar job for a buddy, still had a noise in the rear right side.it sounded like tire rub. i rode in the back while he drove and found the bushing to be shot, even if it doesnt look like it. he had a 1.5 in drop
The Rub would happen before I Replaced the struts and springs, Used to have really old koni's and neuspeed springs.
Could it be something wrong with the Toe rod?
Check the Trailing arm bushing. They are easy to replace , if only one is shot i would replace both of them ( one one each side ).
If it is bad, it would change the ride height ever so slightly. Another culprit may be body work to the notorious fender wheel.
The Grumpiest
I also asked you how low you were. Do we have a problem answering all questions? I asked you how low you were as well. Good luck figuring it out.
That guy sure is grumpy. How is your RTA bushing? If your car is lowered, and you didnt replace this with a new, clocked bushing, odds are its torn on the bottom. Check that first, then get back to checking the rest of the suspension.
I Checked my RTA Bushing Yesterday and it looks like it could be torn. I plan on changing both sides out and seeing how that goes from there
osix
11-21-2015 10:43 AM
