Transmission swap help
So I just got done finishing up my transmission swap(auto EX to manual EX) and I started my car and it won't go in gear. If the clutch is engaged, my speedometer will shoot up to 30+ mph and just sit in my driveway haha. What's going on with it?
Re: Transmission swap help
im assuming this is with the car in the air still? if so your clutch isnt fully engaging and you need to bleed more. i find when helping push the shift fork in pushing the slave all the way in when the pedal is stuck to the floor helps get all the air out. then tighten it up and let go then rebleed a few more times...
O.G. triple O.G.
Everytime you install/remove a transmission, you have to check the clutch pedal pressure. Bleed the system if necessary.
