Fuel pump not priming sometimes please help
Old Apr 15, 2013 | 06:16 PM
Chris del sol's Avatar
Default Fuel pump not priming sometimes please help
Hey ht. i have a problem with m dd! lately i been switching my car to on(ll) (94 Honda si) and my fuel pump primes but sometimes it does not prime at all and car has turned off on me twice this week while I was driving. I pulled over and fuel pump did not want to prime at all till about 20 min later. I checked the main relay and it was good, can it be the fuel pump is going out? Thanks in advance
Old Apr 15, 2013 | 07:57 PM
RlMcCoy71's Avatar
Default Re: Fuel pump not priming sometimes please help
I would start by checking to see if you have 12v power at the pump when its not priming. But, with it shutting off while driving and not wanting to start for 20 min does sound like the pump getting hot and shutting off, then after cooling begins to works again. If you change your pump be sure to change the fuel filter too.
Old Apr 15, 2013 | 07:58 PM
apexi_rsx's Avatar
usually this is the fuel pump relay shyting out. they usually Start to unsodered apart giving a short or loose connection
Old Apr 15, 2013 | 08:25 PM
K PORT's Avatar
fuel pump. get a new one or even used. reccomend new though. I had one off of my ek and put it in my ex's Eg and it worked fine. Only reason I did that was because I knew it worked fine before I put my walbro in.
Old Apr 16, 2013 | 10:07 AM
Ok, I have a kill switch to the fuel pump can that be taking that be throwing the 12v? I've checked the wiering there is no short it is clean.
Old Apr 16, 2013 | 01:30 PM
TIMMY4TOES's Avatar
I would lean more towards the fuel pump relay. go to the junk yard and get one quick. it would be alot cheaper than buying the fuel pump. Also trace the wires around see nothing looks pinched and damaged.
Old Apr 16, 2013 | 03:10 PM
The relay looks good but I will swap it. I just finished putting my brothers civic fuel pump in my civic but it still did not prime :/
Old Apr 16, 2013 | 10:38 PM
KidKavika's Avatar
The relay will usually always look good. It's the cracks in the solder points that most people over look and think its not the relay when really it is. Just my .2
Old Apr 16, 2013 | 10:42 PM
KidKavika's Avatar
I had this same problem many times. The relay wont respond while its hot. You give it 15-20 min to cool and it will start right Up again. The first time it happened to me I thought the same as you are now. Then I got a buddy's relay and determined that it was a relay issue. The relays can be easily repaired with some new solder or you can get a replacement for fairly cheap. Any civic, Integra, accord relay will work.
NovaRex
Dec 4, 2015 05:10 PM
hatchBK4life
Aug 2, 2010 05:11 PM
93FlatBlackHatch
Dec 30, 2006 03:22 PM
ill phil
Apr 23, 2003 11:58 PM
