antifreeze overflow tank problem.
I bought a ej2 and i noticed the overflow tank was dirty. I open my radiator cap and pressure comes up from the overflow. My radiator also has some funny lookin brownish stuff inside it. I bought a new radiator n cap n still the samething. I havent had a problem with temp n never over heats but what can it be
Re: antifreeze overflow tank problem.
The "brownwish stuff" is probably oil. Flush you'r rad,refill then bleed it drive it for day or so see if it comes back.
If it has that "brown stuff", more than likely your head gasket is going out. try what the second post said first. Good luck
As everyone said.
Once flush check and see if your losing coolant or filling up the over flow.
If so its more or less a headgasket. Just delt with this a few weeks ago.
Confused. Man did a gasket when i did a full tune up when i got the new cap and rad. Some1 said it could be a waterpump issue?
Could be residual from the previous bad headgasket. Oil floats so it's going to find its way to the upper radiator tank. Also, if oil got in your coolant all the hoses may start to deteriorate. Rubber and petroleum products don't mesh well unless they were designed for that purpose. A set of all the hoses for your car can be had at the Honda dealer for a reasonable price. You may want to verify that your headgasket is intact before investing in any ancillary parts.
bark3rk20
23
04-18-2009 09:25 PM
dynastix9
12-18-2005 06:33 AM
