Gsr swap front o2 sensor need help!
I bought a 97 civic with a gsr swap in it and its throwing a code for the o2 sensor. It came wire tucked and I can't find the connector for it so I tried to wire it to the ecu with no luck. Correct me if I'm wrong but denso blue wire is signal, white is ground and the 2 blacks are heater wires. I found the ecu diagram from ffsquadtech. Any help would be greatly appreciated!
Re: Gsr swap front o2 sensor need help!
are you looking for the pinout ? it's a bit hard to understand from you'r OP obd2 to obd1 via a jumper ? or obd2
BlackCivicEX
29
01-21-2011 07:19 AM
Ls1 FD3s
08-27-2007 06:44 PM
