rattling/vibrating by pulleys
alright just got back from a 8 hour drive and when i coming home i notice a rattling noise by the pulleys .almost sounds like a exhaust leak but i think its something else.it happens when parked and i give it gas and moving giving it gas .but it has to be a high rpm any ideas
Re: rattling/vibrating by pulleys
start of by inspecting everything of the suspected area,making sure all pulleys are tight, belts, axles. check anything you can that spins for play. its happening in my car and seems pretty common is the input shaft bearings in the transmission going bad. hopefully thats not your case.
the radiator hoses go from the radiator to the head and thermostat. are you thinking a/c condensor? is there a/c in your car? perhaps the a/c clutch bearings are worn. check the a/c pulley for play. i know mine came with a/c.
jamesmoua
Honda Civic (2001 - 2005)
08-07-2017 05:13 AM
