IAVC Problem
IAVC Problem
Okay after i put on my new intake manifold, i threw a cel. So i checked it and it was the iavc. would this affect any kind of performance? The only thing that i noticed is that when i first start the car up and it is cold it just idels normal. So in other words i dont have a cold start idel.
Re: IAVC Problem (barto)
like what? i told you it dose not have a cold idel, and that it started as soon as i put my new intake mani on. And that this is the only problem that i have noticed. i just wanted to know if it would have any other effects other than the cold idel thing.
Re: IAVC Problem (sohcvtec1995)
does the car idle real shitty and low? when i didnt have my IACV wired right,..it did not have a cold start,...and it idled real low and shitty,...if i was you,..try taking the IACV off the manifold and cleaning it with carb cleaner to see if that could fix the problem
BUMP for some help. I went to the track and ran 16.8!!! that is almost a second and a half slower than befor!!!
Re: IAVC Problem (B Cruz)
i did all of that. i even had a mechnic reinstall it. And still the same problem.but would that code make me run that much slower?
well i did not think that this would cause such a drastic loss in time. And the cel came up once i put the mani on. I guess i could look at another civic and check the wires. But i just reall want to know if that is what caused me to run so slow. I mean my car dose not feel any slower, but the track proved me wrong.
bump....
need help as well. i just put a skunk2 IM on my gsr motor in my 00 civic ex. im using my stock ex harness as well. so far as ive read, it says that there should be a plug for the iavc on the ex harness, but i couldnt find it. im having the same symptoms as him, with the bad idle on a cold start etc. how do i go about fixing this problem. need to know asap. do i have to directly wire it into the ecu? thansk.
movingIIshadow
01-14-2006 08:21 PM
