Replacement motor mounts.
Anyone know where I can get polyurathane motor mounts of a D-SERIES engine? not b-series or swap mounts. just polyurathane stock replacement mounts. I know they have the inserts, but I want to try and get the all the mounts replaced. (200K on them) but I've see all new mounts befor on Ebay but I don't see them there any more. just wonding if any one knows where else to get them?
Re: Replacement motor mounts. (a f'n j)
if you decided that you want the energy suspension inserts, i just got a hyperflex kit for my car but i have a bseries swap so I don't need the motor mount inserts.
like $25 + shipping
like $25 + shipping
I'm also looking to replace my motor mounts on my D16. Had any luck? All I find are for swaps. Hasport makes nice ones, just not for our engine. I want to replace the whole mount, not just the inserts.
Anyone?
Anyone?
Re: Replacement motor mounts. (HiVolume.com)
http://www.jimfab.com
probably the second best thing i've done yet.
fyi, when doing a B series swap into the 96-00 civic you acutally retain all of the stock rubber mounts. you only need the brackets that bolt the mounts to the block from the B series engine. so, the hasport kit will work on your D16. (i've never used it though, you might want to double check with hasport first)
Also, if you're on a budget you can always use the DIY methods.
Either with the ES inserts: http://www.homemadeturbo.com/t...ounts/
Or without them: http://importnut.net/motormount.htm
D16SohcVtec
08-12-2008 08:03 AM
